Heated front windscreen connections -
Old Jul 2, 2019 | 05:17 AM
RJ5's Avatar
RJ5
Default Heated front windscreen connections -
Have a 97 Disco that has the heated windscreen. Has factory connections for it on each side under the cowl.
My question is - do they both need to be connected at the same time or just one depending on the right-handed / left-handed driver configuration?
i think it’s both but can find information to confirm. Had some work done on my truck a few months ago and the windscreen had to be removed - used the heat the other day and noticed it didn’t seem to be working evenly - looked under the hood and see that it’s only connected on the left hand side. Thinking the right just didn’t get plugged back in I removed the cowl enough to feel around for the lead from the windscreen and nothing’s there. Then I started questioning myself if it ever was there in the first place...
Old Jul 2, 2019 | 06:23 AM
ihscouts's Avatar
Question no more. It should be hooked up on both sides, the service manual shows two connectors (C121/C122) to the screen.
Old Jul 2, 2019 | 02:32 PM
RJ5's Avatar
RJ5
Cheers ihscouts - thanks for the reply. They obviously didn’t pay attention when reinstalling - lead is probably just hanging on the inside instead of out.
Old Jul 2, 2019 | 03:31 PM
ihscouts's Avatar
That was my thought too RJ5. They reinstalled it happy to get it to seal and in their euphoric moment.......they let you down......
That's a feature I wish I had, not euphoria but a heated windshield. I've had euphoria, she wasn't that good.
Old Sep 11, 2019 | 02:37 PM
RJ5's Avatar
RJ5
Update: Took her back to the shop that screwed up and had them remove the windscreen (after them doubting there was two connections) - sure enough there the plug was. All heating elements working again .
apex944
Feb 2, 2018 02:53 PM
MillerMonteSS
Mar 6, 2015 11:49 AM
phatduc
Mar 21, 2012 05:01 PM
gavone1976
Apr 3, 2011 09:40 AM
