Heater Blower motor/fan Disco 1
Old Oct 21, 2021 | 04:35 PM
Mark G's Avatar
As I mentioned in another post, it's a real good idea to remove the plastic cowl cover between the hood and windshield, and cut/install a piece of metal hardware cloth over the open air hole (above the blower). There's a large open (uncovered) hole basically open to any and all leaves or rodents who wish to take up residence in the blower. I used some 1/4" (dimension of squares) wire cloth and bent it down over the lip. Applied some daubs of RTV in a couple places to hold it in place. Don't drill holes and put screws straight down, you could end up with leaks into your cabin. Then replace the cowl pieces. Takes 1/2 hr or so. Doesn't impede airflow. You can get it any just about any hardware store or Tractor Supply (Farm N Barn) type place. Or a guy could get some aluminum Stucco backing at a home center which would work too. I don't have any pictures unfortunately.
https://www.truevalue.com/galvanized...h-24-in-x-5-ft
Old Oct 21, 2021 | 07:03 PM
caniwi's Avatar
Default Blower
It's really straight forward. Just a nuts and bolts kind of job fortunately. Drop the cardboard kick panel off, remove the glove box and you will see the blower right there.
Old Oct 21, 2021 | 09:19 PM
disco96sd's Avatar
should I get the Land Rover part for $500 or should I get the knock off for $30 ??
hmmmmmmm - or used Land Rover part ?
Old Oct 21, 2021 | 09:50 PM
caniwi's Avatar
Default Blower motor
Seriously, if you can get a good/used blower motor, that is the way I would go. But I'm frugal lol
As long as the so-called squirrel cage is clean, and the motor turns, you should be good. Unless you are doing a ground-up resto, keep it modest.
mr4x4
Oct 22, 2021 11:14 AM
DKPhoto
Jul 6, 2018 07:46 AM
mskiGT3
Dec 3, 2013 07:24 AM
stevekep
Oct 27, 2013 01:50 AM
newf4us
Freelander
Nov 5, 2007 06:59 PM
