heater and CC don't work
Old Apr 5, 2012 | 06:04 PM
  #21
I would also replace all the coolant hoses since you will have the system drained.
You will need 3 gal of all aluminum safe coolant in the 50/50 pre-mix.
Old Apr 5, 2012 | 07:17 PM
  #22
Danny Lee 97 Disco's Avatar
With a leaky expansion tank, how does it hold pressure?
Old Apr 6, 2012 | 08:23 AM
  #23
filbs's Avatar
It doesn't....
Old Apr 6, 2012 | 08:24 AM
  #24
filbs's Avatar
you know actually the coolant hoses all appear to be relatively new.... the hardware on them as well.
Old Apr 6, 2012 | 08:31 AM
  #25
If hoses are both hot, one would believe that hot water is getting into core, perhaps flap vent is not open. When you get ready to be messy, take off the heater hoses under the hood and flush through the core both ways with garden hose, this will reveal clogged core or not. Standard metric/SAE socket set and screw driver are about it. You can tell if hot hose is water or just radiant heat from engine by touching other hoses nearby. Usually if they are hot, there's water in them. IR thermometer is a nice toy to have.
Old Apr 16, 2012 | 04:02 PM
  #26
filbs's Avatar
so i think I found the problem with my CC....yes that is duct tape someone tried to fix it with........
Reza
Mar 15, 2014 03:32 PM
calebbo
Oct 12, 2011 09:54 PM
Meek
Mar 7, 2007 05:46 AM
mrpcar
Feb 22, 2007 03:17 AM
netprophet
Aug 6, 2006 02:48 PM
