Help
I have a 97 discovery. I have done the head gaskets the timing chain and gears. A cam position sensor and plugs and wires and also a fuel filter. It idles perfect and runs perfect for about 3 miles. Then it has no power. Any help would be apreciated. Thanks
You need to check the fuel pressure when this happens.
Rent a tester, hook it up, cable tie it out of the way, drive.
When this happens pull over, open the hood and check the gauge, then rev the engine by hand and watch the gauge.
Report back with those numbers.
alti
Mar 13, 2013 08:30 AM
Speed racer
Oct 11, 2008 10:56 PM
