Help
Old Jun 19, 2011 | 08:34 PM
Kv6961's Avatar
7th Gear
Default Help
I have a 97 discovery. I have done the head gaskets the timing chain and gears. A cam position sensor and plugs and wires and also a fuel filter. It idles perfect and runs perfect for about 3 miles. Then it has no power. Any help would be apreciated. Thanks
Old Jun 20, 2011 | 04:29 AM
Fuel pressure regulator, or return line, etc.? Crack out the RAVE to section 19 for testing methods. Just for background, how long did it take you to do the HG job?
Old Jun 20, 2011 | 03:44 PM
Kv6961's Avatar
7th Gear
it took me a total of about 12 hrs to do the head gaskets. I have checked the fuel pressure and it has 38 psi
Old Jun 20, 2011 | 04:55 PM
We need a better description of "no power"
Old Jun 20, 2011 | 06:09 PM
Kv6961's Avatar
7th Gear
after i drive the rover 3 or 4 miles. It starts losing speed and the rpms wont go above 2500. But if you let it idle it idles perfectly. If you go to give it gas it has no power
Old Jun 20, 2011 | 06:30 PM
You need to check the fuel pressure when this happens.
Rent a tester, hook it up, cable tie it out of the way, drive.
When this happens pull over, open the hood and check the gauge, then rev the engine by hand and watch the gauge.
Report back with those numbers.
Old Jun 21, 2011 | 09:41 PM
Kv6961's Avatar
7th Gear
I will check that tomorrow and let you know thank you
Old Jun 24, 2011 | 05:58 PM
Kv6961's Avatar
7th Gear
Thank you to all of ya that helped me out. I have found the problem it was the fuel pump. I couldnt believe since I had replaced it 2 years ago. Thanks everybody
Old Jun 24, 2011 | 06:32 PM
Danny Lee 97 Disco's Avatar
Check the price at Rover's North, that is where I got Mine.
Old Jun 25, 2011 | 07:39 PM
Kv6961's Avatar
7th Gear
I got mine from rovahfarm.com for 179.00. I didnt think that was too bad
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
