help!!
Old Jan 14, 2012 | 08:46 PM
disco 96 sd's Avatar
4th Gear
Default help!!
where is the cam shaft position sensor on a 96 land rover discovery sd? ive ran the codes and the purchased the part. but ive yet been able to locate it. if anyone cold let me know it would be greatly appreciated!! thanks!!
Last edited by disco 96 sd; Jan 14, 2012 at 09:10 PM. Reason: i felt not enough information
Old Jan 14, 2012 | 11:29 PM
It's on the front of the engine. Here's the page from the RAVE shop manual, free download of the whole thing at link in my signature.
File Type: pdf
Old Jan 15, 2012 | 01:41 AM
EricTyrrell's Avatar
between crank and water pump
Old Jan 15, 2012 | 06:59 AM
No that's the crank shaft position sensor, which is in this pix attached.
File Type: pdf
Old Jan 15, 2012 | 07:54 AM
Jake1996D1's Avatar
Climb under truck, locate oil filter, now look left on front cover you should see a harness . Follow the harness to cam shaft sensor attached by a single bolt I believe.
Good luck!
Old Jan 15, 2012 | 11:16 AM
Oops, smoking too much crank...
yeah cam sensor is right between crank and water pump.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
