Help!!! Brakes go soft after a week
Old Feb 25, 2014 | 11:45 PM
discoken's Avatar
Default Help!!! Brakes go soft after a week
Hi I have a 1999 Disco 1 that was leaking quite a bit from the master cylinder. I bought an aftermarket master cylinder, installed, and bled it. Everything seems OK, but after 5-7 days, I lose all brake pressure. This has happened twice now. What should I do? Thanks.
Old Mar 7, 2014 | 10:27 AM
discoken's Avatar
Any suggestions disco gurus? Should I buy a factory master cylinder instead and replace the aftermarket one I bought?
Old Mar 7, 2014 | 10:57 AM
Snowdog's Avatar
Are you sure it's leaking from the master cylinder? Could be a brake line or caliper that has a leak… Is the master cylinder fluid level dropping? If not, maybe you didn't get all the air out of the lines. I've had vehicles that had to be vacuum-bled to remove all the air, the traditional methods wouldn't remove some substantial air bubbles causing a very inconsistent braking action.
Old Mar 7, 2014 | 03:29 PM
ihscouts's Avatar
Yes, buy a genuine LR master cylinder. Aftermarket don't work. Your either going to experience lock up or your issue. Serious as a heart attack.
FightOnUSC79
Nov 26, 2010 09:43 AM
m1964
LR2
Nov 17, 2008 09:49 PM
johnnybob06
Oct 10, 2007 10:50 AM
Rob S
Jan 5, 2007 09:44 PM
red rover 99
Jul 12, 2006 04:39 PM
