Help with disco 2 driveshaft intall in to disco 1
I ran the DuraTracs for about 30,000 miles. They were a great tire, excelled in everything but thick mud. They still had about 60% treadlife left when I sold them.
Got a transfer case output flang and paragon brake lines ordered today. Thanks for the imput guys! One question. For the rear drive shaft, getting rid of the flex joint, can I get another front off a d2 and have the double Cardin joint cut off and welded to the existing rear shaft. Then buy a different imput to the rear differential? What's the easiest and most cost effective way to get rid of the rotoflex? Thanks.
What you need to convert the rear driveshaft is offered in kit form from Atlantic British. Drive Shaft Conversion Kit For Land Rover Discovery Vehicles
You're definitely going to want to get rid of that RotoFlex with 3" lift. The question that you'll face though is: Do you need a regular driveshaft back there, or a Double Cardan? That will depend on your pinion angles, which you won't really know until you lift it.
At the very least you'll need the four-bolt flange for the rear diff.
Paul Grant on this board may be able to get you the kit too with good used parts to save some money. Nothing wrong with a used flange and rebuilt driveshaft.
robert.juric
Nov 3, 2022 06:08 PM
NW_rockhound
Jul 30, 2008 08:13 AM
What +size ax stops do you have stuffed in there? I kind of see the left, +2?
