Help please! Something is binding when I hit the brakes in reverse.
Old May 22, 2012 | 08:16 PM
  #21
fishEH's Avatar
Originally Posted by Danny Lee 97 Disco
Broken caliper bolt, caliper moving.
Not so fast, Danny Boy. I called it back in post #10.
Originally Posted by fishEH
Also check your caliper mounting bolts. Perhaps an upper bolt sheared off. When braking forward its less noticable because wheel direction seats the caliper. In reverse the wheel direction could cause the caliper to pivot up and back, perhaps causing a binding sensation.
Old May 22, 2012 | 08:18 PM
  #22
Jake1996D1's Avatar
It would pull like hell when you hit the brakes
Old May 22, 2012 | 08:19 PM
  #23
Mountain Goat's Avatar
That was actually the first thing I checked. I'll check it again when I get the wheels off, haven't had time yet so I'm driving the Ranger for now...
Old May 22, 2012 | 08:24 PM
  #24
So if it comes to this, I'm assuming pulling the e-brake drum requires removing the rear driveshaft, right? While I have it off can I tack weld the studs so they don't spin in the drum? I would probably use TIG so I can do a very small spot. I've had problems with the studs spinning when removing/reinstalling the rear driveshaft in the past.
Old May 22, 2012 | 10:09 PM
  #25
Yes...
Old May 22, 2012 | 10:11 PM
  #26
Danny Lee 97 Disco's Avatar
I was just seconding your point Fish. I remember one previous wildguy who drove his using the P Brake because his front caliper was dangling.
You can do that or buy replacement screws.
Old May 23, 2012 | 10:41 AM
  #27
wheelgarage's Avatar
I hope you don't find that creature from "Big Trouble from Little China" under there......
Old May 23, 2012 | 12:28 PM
  #28
Might be a swamp critter hiding in there.
doogaloo
Apr 7, 2015 07:40 AM
houm_wa
Nov 20, 2014 01:47 PM
suzukisam967m
Sep 23, 2012 05:36 PM
bothomasmusic
May 24, 2011 12:47 PM
IanWhitefeather
Nov 13, 2010 05:45 PM
