High Idle 97 Disco
Old Apr 21, 2016 | 07:35 PM
DiscoInferno97's Avatar
Default High Idle 97 Disco
I have tested all of the usual culprits and the only thing that I can come up with is that my iac thinks it's -39 degrees. I have tested the signal wire and the ground and they are both good. Btw the sensor is brand spanky out of the box because I figured it was the problem.
Could anyone please offer some insight into my issue?
Old Apr 21, 2016 | 08:29 PM
RedRovin''s Avatar
IAC or IAT? I assume iat, because that reads intake air temp. Iac controls idle flow. While I can assume you mean one thing though, you could have replaced the other. If your iat is new though and still reading -39 then there is an electrical problem somewhere. If you replaced your iac, then you need to look at your iat.
Old Apr 21, 2016 | 09:06 PM
Thank you RedRovin', I did mean IAT Sensor, just put it in today.
Old Apr 22, 2016 | 06:13 AM
RedRovin''s Avatar
Okay, that's good. Sadly I haven't learned too much about the iat and it's communication with the ecm. The RAVE has little to no information about its operation. I do know that prior to starting my truck, my scangauge says -40 for the temp reading, but once it's established connection it will read normal. Also, if I disconnect it, the number auto jumps to 199. Based on that info, I would guess that your iat is not sending any info to the ecm at all. I would trace back the wires and see if it's grounding out somewhere or cut. Hope that helps
Old Apr 22, 2016 | 07:02 AM
I've already tested the wires (good ground and good connection) that's what has me stumped. But my fuel pump went out trying to start her this morning, hopefully just a wire or a relay.
Old Apr 22, 2016 | 11:40 AM
RedRovin''s Avatar
What are you using to view intake temp? (Scangauge, ultragauge, etc). Have you had the adaptive values reset? I tried everything with that being my last resort and it worked. I had a 1300 idle before and now at 705.
Old Apr 22, 2016 | 02:34 PM
Im using my buddy's snap on modis to check the temp. No I haven't had it reset yet, I need to find a local shop that can do the deed.
wick_60010
Nov 22, 2017 04:25 AM
vpadferg
Jan 19, 2013 09:41 PM
arains44
Dec 15, 2012 03:38 PM
joking41
Feb 9, 2012 11:52 AM
racdisco
Sep 21, 2007 12:01 PM
