how hard could it be
Old Aug 18, 2011 | 11:18 PM
huntitall's Avatar
Default how hard could it be
so i need to put a new trany in my land rover 97 disco how hard is it and could some one walk me thro it
Old Aug 19, 2011 | 05:23 AM
Got the RAVE download? Jsut to supplement any responses you get here. There is a write up in the tech section on the tranny pan, which involves taking out the cross member, has some photos.
Old Aug 19, 2011 | 06:53 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Too easy bud. First get that transmission ready to go in. Clean it up real good. Do you have a new torque converter? Probably a good time to get one if you do not. Have you removed the old trans yet? PM me I can talk you throught he process the easy way.
Old Aug 19, 2011 | 01:39 PM
Rover_Hokie's Avatar
But you do not work at a dealership, how do you know the easy way?
Old Aug 19, 2011 | 02:37 PM
So, what is wrong with the old one, be specific? How mechanical are you?
Old Aug 19, 2011 | 07:16 PM
antichrist's Avatar
Replacing a transmission isn't a huge job.
Follow the steps in the manual, make sure you don't pinch the O2 sensor wires between the bell housing and flywheel housing.
Make the transmission support adapter shown in the manual. It makes removal installation easier.
Saw the heads off some long 3/8 NC bolts, taper them a bit then use them for locating pins in the fly wheel housing when you replace the transmission.
Old Aug 19, 2011 | 11:26 PM
jafir's Avatar
Be careful not to let the torque converter slip out, I guess it can be a problem for some to get them back in:
How to seat a torque converter in the truck? - Pirate4x4.Com Bulletin Board
Old Aug 22, 2011 | 01:03 AM
huntitall's Avatar
okay so the trany dos not go forword but go's in rev i ended up just geting a new trany and converter just cus the trany was sliping any way. $900 later i will be geting it in about two days it should be at my house. so im trying to get info now. so i would like to do this with out pulling the engin but im not sure if thats going to happin. would like any info.
also mike im not as high tec as most of you guys but if im talked throgh it i think i can make it hapen. i can chang brakes redo front ends and just about anything with good info,
Old Aug 22, 2011 | 04:24 AM
In the RAVE download of the workshop manual, go to section 44, Automatic Gearbox; Repair,
LT230T TRANSFER GEARBOX WITH AUTOMATIC
GEARBOX ASSEMBLY - V8i
This is the write up, with detailed very clear drawings, of what to do. Transfer case and tranny come out together, need to fabricate a bracket to balance them on your tranny jack. Details of bracket are in there.
If you do not have this manual, you can down load it for free. IF you decide to go ahead with this, without reading the manual, this is one of those jobs that will go badly, unless you have many of them in the past.
You may read the write up, with check list of all the things to be taken loose and put back, and decide to invest in some shop time with a mechanic. Or call in a favor and get a couple of friends over.
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
kend500
May 23, 2006 11:04 AM
bmwrovers
May 23, 2005 01:02 PM
