i got a1995 disco 1 and it has a hard time starting up
So, when sometimes when I got to start my car it won't start just turns over and sometimes it will turn over for a bit before starting and some times it won't then when I turn it over again it starts right up and some times it sounds like its gonna die when it starts. I don't know if I need a tune up or new injectors, i replaces the wires and plugs thinking that would work but it didnt. Any suggestions? Its the 3.9 v8
![Smile](https://landroverforums.com/forum/images/icons/icon7.gif)
Replace your distro cap too if you didn't already.
Is your idle ok once it evens out (trick question)
X2 on fuel pressure test.
Fuel filter could be clogged up causing fuel volume issues
Fuel pump failing maybe
PCV system clogged up
Check oil separator
Induction and Tbody cleaning can work wonders on startups and idle
CHECK ENGINE LIGHT?
Check oil separator
CHECK ENGINE LIGHT?
Atrain
14
02-29-2020 02:09 PM
