i got a1995 disco 1 and it has a hard time starting up
Old Jul 10, 2013 | 05:15 PM
bigr1122's Avatar
Default i got a1995 disco 1 and it has a hard time starting up
So, when sometimes when I got to start my car it won't start just turns over and sometimes it will turn over for a bit before starting and some times it won't then when I turn it over again it starts right up and some times it sounds like its gonna die when it starts. I don't know if I need a tune up or new injectors, i replaces the wires and plugs thinking that would work but it didnt. Any suggestions? Its the 3.9 v8
Old Jul 10, 2013 | 05:22 PM
May be a good idea to check fuel pressure.
Old Jul 10, 2013 | 06:41 PM
Lord Wert's Avatar
Smile
Replace your distro cap too if you didn't already.
Is your idle ok once it evens out (trick question)
X2 on fuel pressure test.
Fuel filter could be clogged up causing fuel volume issues
Fuel pump failing maybe
PCV system clogged up
Check oil separator
Induction and Tbody cleaning can work wonders on startups and idle
CHECK ENGINE LIGHT?
Atrain
14
Feb 29, 2020 02:09 PM
Jull
Sep 9, 2013 07:00 AM
martini7
Sep 22, 2006 08:18 PM
tover
Sep 20, 2005 11:57 PM
devildogrover
Dec 24, 2004 04:48 AM
