Identity this lift!!! Supposedly 6" and such
Its got the stainless brake extensions and such but the steering arms look stock. What brand of arms are those and what do you think?
Rear
Front
And the stance
Just did some wheelin today so its a little dirty. This thing is amazing! Went up anything like a joke!
Rear
Front
And the stance
Just imagine if it had good tires what it could do.
I HIGHLY recommend you get a set of these for your NATO's.
Lug Nuts - For Steel Wheels - Metric - Set Of 20 for Range Rover Classic | Land Rover wheels, tires, hubs, axles
Looks and safety.
Those are the alloy lug nuts and they are not meant to be used 100% of the time on the steelies.
I have heard but cannot confirm that they (alloy lugs on steelies) work loose and wheels fall off while going down the road.
Those look like Rovertym radius arms and A arms.
Rear Link Assembly with Bushings - Suspension - Rovertym Inc.
http://www.rovertym.com/index.php/Di...dius-Arms.html
Yeah thats no 6" lift just looking at the driveshaft angle. Looks more like 3-4" I can tell you with 33" tires and 5" lift when I measure to the bottom of the body line its 44 1/2" if that helps. They look like Rovertym arms front and rear on it but not sure about the springs.
