I'm scared to ask??
Old Aug 20, 2011 | 01:51 PM
  #41
$350 for everything installed is not bad.
Print off and correct belt routing from the tech section and give it to them.
It is easy to get it wrong and still have it look right.
Old Aug 20, 2011 | 06:50 PM
  #42
I had never done it on a Rover and it was simple, under 2 hours. There is a write up in the tech section for a $49 Chevy substitute clutch, and here are some pix of what to expect on the pump. Several bolts are different sizes.
Attached Thumbnails I'm scared to ask??-p1030594.jpg   I'm scared to ask??-p1030595.jpg   I'm scared to ask??-p1030597.jpg
Old Aug 21, 2011 | 08:48 AM
  #43
wynhd's Avatar
While I was at it, changed my valve cover gaskets, thermostat and oil. Thus far, no oil leaks or coolant and she is running normal temp. Thanks again for all the help.
Old Aug 22, 2011 | 12:25 PM
  #44
wynhd's Avatar
After all the work, my Disco is running ridicuously amazing, I feel like I have more umph going up the hills, idles nicer and actually runs a hair cooler on the temp gauge.
Old Aug 22, 2011 | 11:49 PM
  #45
adigerol77's Avatar
Originally Posted by wynhd
Ok, it's my fan clutch and water pump, I've never done before but, have a facility to do the work, $350 installed.
I started the work myself till the long bolt that goes thru the tc cover broke off. Off to the mech. All back together and running like it should then it hit 110 and 30% humidity at a stop light, temp started to rise again. Off to the rad shop. Should have it back wed latest. Hopefully she will be back to normal. Congrats on your fix, don't bring her to az during the summer though.
Old Aug 23, 2011 | 05:25 AM
  #46
Shake and bake - when U bake, the wallet you will shake....
uncc09meet
Jan 28, 2010 11:17 PM
isofast
Jul 14, 2009 11:35 AM
javoli001
Dec 10, 2007 01:33 PM
evoasis
Nov 17, 2006 10:31 PM
Jason79
Oct 6, 2006 05:40 PM
