Immobilizer issues
Old Sep 6, 2020 | 06:54 PM
Tanner Simpson's Avatar
6th Gear
Default Immobilizer issues
My 99 D1 has been immortalized for about a week now. I tried resoldering the key fob and the eka trick, but nothing seems to work. I’m almost ready to just give up and sell the truck. Can someone please help?
Old Sep 7, 2020 | 08:39 AM
jimvw57's Avatar
Been there! I ended up replacing the alarm ECU and then the main ECU
Old Sep 7, 2020 | 08:43 AM
6th Gear
How much did that cost you?
Old Sep 7, 2020 | 08:46 PM
jimvw57's Avatar
I believe it was around $300 for both. Make sure you use the part numbers on each unit when you get replacement ones.
Got mine from goldwingrover.com
https://www.goldwingrover.com/default.asp
I have 2 fobs that I got with the truck, but have never had them work. Found the wiring down by the A pillar floor on the passenger side were cut and taped back together so I repaired them correctly, replaced the battery, plus a bunch of other stuff trying to get it to work. I did get some success by having the ignition in the on position when I re-connected the battery. The only way I could shut off the horn was to disconnect the battery.
eitydeuce
Jan 30, 2020 11:40 AM
boxsterrs60
May 20, 2019 05:18 AM
Extinct
Mar 17, 2016 06:00 AM
Coyote
Jul 2, 2013 09:33 AM
thomas22
May 10, 2009 10:12 AM
