Immobilizer issues
My 99 D1 has been immortalized for about a week now. I tried resoldering the key fob and the eka trick, but nothing seems to work. I’m almost ready to just give up and sell the truck. Can someone please help?
I believe it was around $300 for both. Make sure you use the part numbers on each unit when you get replacement ones.
Got mine from goldwingrover.com
https://www.goldwingrover.com/default.asp
I have 2 fobs that I got with the truck, but have never had them work. Found the wiring down by the A pillar floor on the passenger side were cut and taped back together so I repaired them correctly, replaced the battery, plus a bunch of other stuff trying to get it to work. I did get some success by having the ignition in the on position when I re-connected the battery. The only way I could shut off the horn was to disconnect the battery.
