Intermittent popping cv
Old Feb 16, 2014 | 08:12 AM
geek_IM's Avatar
Default Intermittent popping cv
Ok so I think I know the answer to this already but I'm throwing up this post to poll others who have experienced this themselves.
Due to all the snow I have been using the diff lock quite a bit over the past several weeks. At random times when I have the wheels turned all the way moving a low speed <5mph like backing out of the driveway - the drivers side cv gives me a pop pop pop. It only happens with the diff locked, and then only on occasion.
Is this my cv on the way out, or just another feature I can ignore? Had everything apart less than a year ago and the cv was tight, no visible wear on the ***** or sockets.
Any thoughts are appreciated.
Old Feb 16, 2014 | 09:01 AM
jafir's Avatar
Do you have oil in the swivel ball?
My 1996 would pop like that when it would run out of oil. That probably means it was damaged already, but since it got quite when I'd fill it up with oil I didn't worry too much.
Old Feb 16, 2014 | 09:14 PM
XCELLER8's Avatar
2x on checking the swivel oil ( or "00" grease)
Old Feb 17, 2014 | 12:20 AM
TOM R's Avatar
do not use diff lock on dry pavement, if it is popping there is too much traction to use diff lock and damage will occur
Disco2Guy
Feb 22, 2008 02:39 PM
Willie 00D2
Sep 23, 2007 08:37 AM
badbowtie85
Jun 18, 2007 11:28 AM
LarDog44
Jun 26, 2006 11:39 PM
