Intermittent Wiper and Dome Light Issue
Old Aug 1, 2012 | 08:55 PM
oljohnboy's Avatar
Default Intermittent Wiper and Dome Light Issue
Hello all,
My rovers intermittent wipers and dome light do not work. The dome light turns on and off but does not activate when the doors are unlocked or opened. I have read a thread that they are related and that there is some "box" that controls these items that need to be replaced. the wipers do return to the start position when turned off. The rear wipers, rear defrost and rear assist light do not work either. I am hoping they are controled by the same thing. Any help is greatly appreciated! John
Old Aug 1, 2012 | 09:03 PM
It is called the MFU, or multi-function unit, size of a pack of smokes, mounted on back side of fuse panel under the dash. It controls short time intervals for lots of things. I snagged one out of a donor vehicle. You could also try a dismantler. IMHO a swap to LED lights inside will extend life of this device (it dims the light on exit).
Old Aug 1, 2012 | 09:12 PM
What Buzz said.
Old Aug 2, 2012 | 12:20 AM
oljohnboy's Avatar
I bought a fuse panel with the MFU attached off eBay for around $45. It has to be the issue. I had no idea how many functions are times on the rig. Thanks guys.
Old Aug 2, 2012 | 04:42 AM
Look at https://landroverforums.com/forum/di...problem-40965/ - check the side of you model to be sure there is not a hole melted in your plastic. LED interior lights really help cut down on this. Diag list from the RAVE:
Diagnostic Procedure
1. Close all doors and the tailgate.
NOTE: If the oil pressure switch goes open circuit
(engine is started) during the following procedure,
the MFU will exit the diagnostic mode immediately.
2. Press and hold the heated rear screen switch
and switch on the ignition.
3. Release the heated rear screen switch within 2
seconds and the MFU will beep to indicate that it’s in
diagnostic mode 1.
4. Press the heated rear screen switch; the MFU
will beep twice. In turn, operate each of the following
switches, heated front screen, rear fog guard lamps,
side lights, headlights, front wiper and rear wiper.
The MFU will beep twice each time a switch is operated.
5. Pressing the heated rear screen again will cause
the MFU to enter diagnostic mode 2.
6. The MFU will provide outputs to the following in
order given below:
Heated rear screen relay energised for 2 seconds
Heated front screen energised for 2 seconds
Courtesy lights energised for 2 seconds
Dim dip relay energised for 2 seconds
Rear fog guard lamp energised for 2 seconds
Headlamp power wash energised for half a second
Front wiper energised for half a second
Rear wipe/wash energised for half a second
7. The MFU will then exit the diagnostic mode.
Old Aug 2, 2012 | 11:17 PM
ihscouts's Avatar
They are not related. The park issue is because of a sun gear with embedded contacts which has a riveted plate covering it on the wiper motor assembly. In days gone by the suggestion was to replace the wiper motor. I took mine apart since I'm not going to waste what I have. Nylon gear with copper contacts. The nylon gear will be pitted from arcing as the motor contact steps onto or off of the copper contacts embedded in the gear. Fill pits with Super-glue and remove melted nylon from slip contact and wipers will now park. Arcing is a problem with these trucks and switches.......
Check to make sure the door button switches aren't sticking, shoot them with a lube type contact cleaner. There is a MFU cycle check in the Rave, it goes through a pretty decent amount of checks. Check your dome light switch too, the position for the light to come on with the door open. Clean it.
Old Aug 3, 2012 | 07:46 PM
See, a real answer from someone who knows.
Thanks IHScouts.
Old Aug 3, 2012 | 09:14 PM
ihscouts's Avatar
I know nothing, just bs.
Old Aug 3, 2012 | 09:40 PM
It's all BS brother, its all BS.
real_tea
Apr 7, 2013 09:45 PM
KennAR
Dec 26, 2012 04:20 PM
Summitdog
Jan 19, 2012 11:11 AM
Savannah Buzz
May 21, 2011 11:05 PM
englishboyonice
Aug 18, 2005 07:23 PM
