just got a 1998 Disco 1 but whats wrong with it?
Old Aug 23, 2011 | 01:30 AM
punkarockaboy's Avatar
Default just got a 1998 Disco 1 but whats wrong with it?
Hello,
I just got a 1998 disco 1 about a month ago and I’m hooked I love it. It has 98000 miles on it no rust super clean from the inside out, But there is something wrong with her and I’m not sure what it is?
It makes this whooping sound from the back end it starts at about 20-35 mph and gets faster as I go faster and stops when I stop moving. I’m going to be working on her Wednesday, I want to know where to start looking, I’m planning on changing all my fluids you know T-case, Difs and Trans also changing the rear rotors and pads wheel bearing. So far I have grist all the drive line points. O and I can’t get it to go in to 4lo. Please let me know what info is out there
Thanks
Old Aug 23, 2011 | 07:43 PM
Could be low on gear lube in the rear diff, could be a bad wheel bearing.
Start by changing all the fluids, checking the level of them first so you have a idea of how well it was taken care of.
I use 75w-140 gear lube.
Dont worry about the 4-lo right now, first things first.
Report back if the noise is still there.
You can spin each tire by hand if it is off the ground and listen for the noise.
sideshow
Oct 27, 2013 10:11 AM
punkarockaboy
Aug 30, 2011 04:27 AM
jbm6287
Dec 10, 2010 08:33 PM
jycsalas
Jul 7, 2009 09:57 AM
angelinajolie
Dec 21, 2005 10:31 PM
