Just two codes P0150, P0153, Change oil 15w40 RP
Old Nov 14, 2011 | 04:11 PM
Discolife's Avatar
Default Just two codes P0150, P0153, Change oil 15w40 RP
I can imagine there are some attorneys on this board, but just saying worked sucked today. Came home early.
Tested alt. its good, tested battery, its good.
Threw codes today as it did on Saturday when we got her.
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
I am just assuming that maybe my connector is buggered up or has oil in it?
Old Nov 14, 2011 | 06:02 PM
RP is good oil, but since you should be changing every 5K, you are spending money for long drain interval you should not use. Agree on your ideas for O2 connectors.
Old Nov 14, 2011 | 06:43 PM
Are you a RP rep?
Do you drive 50k per year round only change your oil every 15k?
Ditch the RP.
As for the O2 codes, check the connectors (hehehe, good luck with that!!), 90% of all O2 codes on a Rover are due to the need of a tune up.
I know your engine is new, but what plug wires does it have?
Cheap plug wires will not hold up and you will get mis fire and O2 codes.
Old Nov 14, 2011 | 08:46 PM
Discolife's Avatar
Originally Posted by Spike555
Are you a RP rep?
Ditch the RP.
It has new plug wires, royal purple rocks, I ll clean the connections tomorrow, royal purple rocks.
The engine rebuild etc was handled by the Ft worth Dealership. She runs great. Royal purple rocks......
Old Nov 14, 2011 | 09:25 PM
Laugh out loud!!!
Its all good man, its all good.
The connections for the O2's are ontop of the bell housing, under the coils, you need to remove the coils to get to them.
4 nuts hold the coils on.
You can leave the plug wires connected and move the coils out of the way.
Old Nov 14, 2011 | 09:27 PM
Discolife's Avatar
Laugh out loud!!!
Glad you have a sense of humor. I only have two nuts that hold me down. Those coils must be strong LOL
workinghard1713
Apr 16, 2012 11:25 AM
psykokid
Oct 12, 2011 08:21 AM
collin Barrows
Aug 28, 2011 07:13 AM
Todd-Squad
May 10, 2011 11:30 PM
