Key and key fob questions
Old 11-24-2011, 03:54 PM
Discolife's Avatar
Default Key and key fob questions
I was wondering if the dealerships cut keeys from codes? Whats the usual charge?
How much do they charge to program remotes?
I have 4 key fobs and a bunch of crappy copied keys that work sometimes
Old 11-25-2011, 11:38 AM
Discolife's Avatar
I am going to try this:
The pushbutton keys are numbered Key 1 through Key 4. When ordering a key, you specify the number. You can only have one of each number. So for example, if you have a Key 2, and you order a second Key 2, only one of those keys will work the remote locking system.
The keys are identified by stickers which unfortunately wear off with time. The result: you kind of take your chance on key numbers when ordering new keys, unless you have the foresight to write your numbers in your owner’s book.
Synchronization of keys on these models is pretty easy. Put the key in the driver door. Turn it to lock while pressing the lock pushbutton. Hold for 5 seconds. Turn to unlock, press unlock and hold 5 seconds.
At that point, the vehicle should lock and unlock via pushbutton. If you cannot synchronize any keys the switches in the door latch may be bad, and I suggest you attend to that right away as the car will be stranded is security sync is lost.
fivehands
14
01-16-2021 01:54 PM
Strikker
10-08-2015 09:19 PM
davidshawbass@gmail.com
03-05-2010 11:05 PM
pilsner
04-07-2008 03:24 PM
Jay
04-27-2005 03:49 PM
Quick Reply: Key and key fob questions
