Sponsored by: CARiD
Horn not working
Old Dec 22, 2013 | 09:32 PM
kipper1080's Avatar
Question Horn not working
I have a 2007 LR3 HSE and my wife noticed the other day that the horn was not working. I have read some other threads on this issue and have looked under the dash to see if there was anything that stuck out. The horn will work when I turn the wheel 90 degrees in either direction but not when it is straight. I am wondering if it is the rotary coupler that others have talked about? Any help would be much appreciated.
Old Dec 23, 2013 | 03:55 AM
You have pretty much nailed it down. But review this part from the manual, could be something simpler. https://www.cubby.com/pl/LR3+worksho.../413-06%20Horn and certainly before tearing into steering column look at that section of shop manual as well.
Old Dec 23, 2013 | 09:20 PM
kipper1080's Avatar
I looked at the horn section of the manual but it does not talk about or reference the rotary coupler at all. I am going to keep digging to find more about it but knowing the horn works without changing anything tells me there is a bad connection when the steering wheel is straight. Thank you for the information.
Old Dec 23, 2013 | 10:00 PM
jafir's Avatar
I think there is a recall for this on some LR3.
http://www-odi.nhtsa.dot.gov/acms/cs...8V248-1996.pdf
couzteau
Jul 30, 2012 09:22 AM
mwood2121
Mar 23, 2011 01:31 PM
lipadj46
Aug 13, 2009 07:47 PM
johnkbl
Dec 29, 2008 11:15 AM
