LED Interior Light conversion
Old 05-27-2011, 07:57 PM
Default LED Interior Light conversion
LEDs draw about 10% of a regular bulb, a lot easier on that wimpy Multi Function Unit module. Photos of my D1, front light LED, rear seat still factory. I soldered mine in, but they make ones that snap in like a regular bulb.
Attached Thumbnails LED Interior Light conversion-p1020476.jpg   LED Interior Light conversion-p1020477.jpg
Old 05-27-2011, 10:38 PM
Where did you get it?
How much was it?
How long to install?
Where do you get the "pop" in ones?
Old 05-28-2011, 04:13 AM
I think I was in Auto Zone, one of the national chains; it was about $16; it took under 30 minutes to install. www.superbrightleds.com is one on-line vendor that makes the snap in modules.
Old 05-28-2011, 07:40 AM
Does it dim after you shut the door like the old bulb or does it just go out?
Old 05-28-2011, 11:34 PM
nevada ben's Avatar
Where does the wire to this light come from? Because I have the light but there's no wire. The garage door opener has a little tab on it with live contacts. Is there supposed to be a jumper cable from the opener to the dome light or is there another pigtail off the harness? Mine's a '98 D1, missing something obviously, probably from the headliner job.
Old 05-29-2011, 10:35 AM
It does dim in steps just like the regular bulb. I soldered mine to the two tabs that support the bulb, I think negative was on the right. You can buy ones from superbrightleds.com that just pop in like a regualr "festoon" bulb.
RWAC94
LR2
05-03-2015 12:29 AM
TRIARII
12-09-2013 06:24 PM
butcher385
LR2
05-20-2013 10:29 AM
PKG Vitesse
01-24-2013 08:58 PM
outdoor7or24
09-06-2012 10:32 PM
Quick Reply: LED Interior Light conversion
