Lights Install
Old Jun 24, 2014 | 09:14 PM
MM3846's Avatar
the white zip ties on the a-pillar ruin it for me.
Old Jun 24, 2014 | 09:37 PM
Be honest guys all you disco owners wish it was a Rangie
Old Jun 27, 2014 | 07:55 AM
jefsantiago's Avatar
Default 98 Discovery Lights
These are what l have for night wheeling. The Front have pairs of 9" floods center, 5" spots sides and fog lights. The overhead has 24" LED light bar (spot fronts and flood sides mix) and 5" floods sides. For the back, I have 12" LED (spot/flood mix) and a 5" spot.
Attached Thumbnails Lights Install-2014-04-07-13.28.55.jpg   Lights Install-2014-04-07-13.29.18.jpg   Lights Install-2014-04-07-13.29.07.jpg
Old Jun 27, 2014 | 09:33 AM
fishEH's Avatar
I want to see your switch set up for all those lights.
Old Jun 27, 2014 | 10:08 AM
Default 98 Discovery Lights Switches
Here you go...
I used the OEM drive light switch to power my front fog lights so it will turn off when the high beam is used. I used the OEM rear fog switch to power the front floods and side spot lights (output wires from the rear bumper going to the front). The PIAA switch/relay powers the overhead LED and side spots. As for the rear LED and spot, I just patched in with the reverse light circuit. I'm planning on putting toggle switch to power it independent of the reverse but just haven't gotten around to doing it.
Attached Thumbnails Lights Install-20140627_074806.jpg   Lights Install-20140627_074813.jpg
Old Jun 27, 2014 | 11:20 AM
HammerFit's Avatar
Here you go...
So the two center front lights are on the OEM drive switch? They are on when the low beam headlights are on?
Old Jun 27, 2014 | 12:01 PM
No, the fog lights are (amber). They are on with low beam and turns off on high.
The 2 center front lights (9" pair) and the side facing (5" pair) are on the oem fog switch (used to light up the rear bumper lights). Always on with the headlights (high or low).
Old Jun 30, 2014 | 08:54 PM
socal1200r's Avatar
And the stock charging system can handle all those extra lights?
Old Jul 1, 2014 | 06:29 AM
Default 98 Discovery charging system
Apparently so. I've gone out a number of times at night - ranging from 2-6 hours of continuous use of all. I have the 100 Amp alternator and the AGM battery from Autozone. Oh yeah, and a 75 watt solar panel that always charge the battery when not in use.
robdis96
Feb 22, 2013 07:07 PM
sickws6
Jan 8, 2012 12:48 AM
Doral300sc
Feb 6, 2010 03:59 PM
j.dstasio
Dec 9, 2009 09:10 PM
RjBu
Oct 14, 2009 10:41 AM
