Looming brake job... How far should I go?
Old May 20, 2014 | 05:30 PM
wrongway1's Avatar
Default Looming brake job... How far should I go?
Getting ready to do the brake job I've been putting off. Along with replacing the calipers, soft lines, and hub bearings, I'm thinking about going with EBC brake rotors w/green stuff pads, but cannot find much on the forum about them. Has anyone installed/had good service from them?
My next question is since I'm going to have that much torn apart, would it be a good idea to keep going & replace the swivel pins & bearings as it doesn't seem to be that much more ripping & tearing once I have everything apart for the brakes? I'm still having some occasional wheel wobble at higher speeds coming off of bridges.
Old May 20, 2014 | 05:36 PM
abran's Avatar
Go with the D90 rotors and calipers. I have had good success with the EBC green stuff pads. But definitely do the defender brake rotors and calipers. They have the slotted/vented sections in the middle making them wider than normal D1 thus making new calipers necessary.
Old May 20, 2014 | 06:47 PM
wrongway1's Avatar
Will look into the D90 calipers & rotors. Do you know if there's a difference in the soft brake lines between the Disco & D90 for the front calipers? I know the rears are the same. Doing to go with the stainless replacement lines.
Old May 20, 2014 | 09:23 PM
ihscouts's Avatar
Plug and play.
Old May 20, 2014 | 11:07 PM
CUpgt's Avatar
Just have to bend the hard line a little to make it fit the d90 caliper
Old May 21, 2014 | 02:45 PM
wrongway1's Avatar
Bending sounds scary without the proper tool. Can I avoid bending with a longer soft line?
Old May 21, 2014 | 05:24 PM
abran's Avatar
Bending is easy, think bending a wire hanger without creasing it.
Old May 21, 2014 | 06:26 PM
CUpgt's Avatar
Super easy to bend it.
Buddy Lee
Oct 2, 2014 10:04 PM
TRIARII
Oct 21, 2013 09:49 AM
cobbcj7
Mar 6, 2013 05:29 AM
sha0lin40
Aug 24, 2012 05:05 PM
DiscoIIBrandon
Aug 13, 2010 04:15 PM
