Loss of Power
Old Jul 4, 2010 | 12:02 AM
  #31
Spencerfitch's Avatar
I was going to post up to check and make sure you idle is at 700RPM [hard to do without gauge] because another thing I learned today is that these things can idle at 350RPMS!! Engine is SO QUIET YOU CAN TELL ITS ON and it runs REALLY cool, BUT. if you decererate from high speeds it will die.
Dont ask how I got my truck to idle at 350RPMS, no I didn't do it on purpose but I do know how to do it now and Id rather not say so that yall dont F up your trucks. Anyways. I was coasting in neutral to a redlight and had looked at my gauge and engine was off. Started it going 50MPH lol.
So a low idle will kill while decelerating sometimes and DEFINATLY gives you that hesatant feeling when accelerating if you dont gradually induce gas.
Old Jul 4, 2010 | 08:48 AM
  #32
Man, stalls below 2000 rpm...I would say a bad/clogged IACV BUT when that goes bad typically it will not idle but as long as you keep the rpms above 500 it will still run.
But you say you must keep it above 2k?
Old Jul 4, 2010 | 11:09 AM
  #33
discomedic4's Avatar
It will run if I keep it above 1000 but still tries to bog down. I was holding it around 2000 or a little less. Am I about to get snowed on my disco here? I love her but I can't start sinking tons of money into her. Prior to this little fiasco she was idling right around the 750 mark. This all just came out of the blue.
Old Jul 4, 2010 | 11:18 AM
  #34
So based on what you are saying spike and the fact that I am getting good fuel at the rail maybe I should start with the IACV. Looks like AB has them for about 170 give or take. What do you think?
Old Jul 4, 2010 | 12:08 PM
  #35
I think you can find them for less than that, try autozone amazon
Old Jul 4, 2010 | 04:49 PM
  #36
Oh I will definitely shop around I was just wondering if that seems like the logical place to start, replacing the IACV. I saw another post on here that said the stall on take off is most likely the camshaft position sensor. I guess I will start with the IACV and just start replacing everything in order until she clears. It's gotta be one of them and they can all cause the symptoms. No real good way to determine which it is except to start replacing them.
Old Jul 4, 2010 | 04:55 PM
  #37
Good news. Napa carries the IACV for 57 bucks. I will get one first thing Mon and go from there. Will keep everyone posted for future reference on this same problem for newbies.
Old Jul 4, 2010 | 05:20 PM
  #38
If the IACV does not fix it I would stop and think, no need to start going broke unless you want to replace everything.
We have a Rover tech on here and he might have a better idea.
But for the $60 thats where I would start and make sure the port is all nice and clean when you put it in.
Old Jul 4, 2010 | 05:36 PM
  #39
Danny Lee 97 Disco's Avatar
Man, that is such a major diff in the prices, how do they justify that?
Good Luck with your efforts.
Happy Fourth of July Everyone.
Old Jul 5, 2010 | 03:29 PM
  #40
So I replaced the IACV today and guess what. Now my engine idles at around 2000 RPM give or take a little. So what gives? Should I also try the TPS as this seems similar to Spencer's problem with the whole high idle thing. What do ya'll think?
