Low/rough idle issue when started with a hot engine
Old Jun 23, 2017 | 05:47 PM
cmpeng's Avatar
Default Update: 21 psi fuel pressure at rail
Originally Posted by rjlsierra
as i said my truck does this also,it just happened to me again after changing everything! try running a bottle of techron it will help,it could be a leaking fuel injector or valve stuck open a little,the techron will help{maybe 2 bottles,1 per full tank}fuel filter should be changed if it never has been,but just check fuel pressure at rail {probably ok if truck starts right up even hot}i.ve also been told it might be an o2 sensor,good luck!
just measured 21psi at the rail/ looks like I need a new pump or pump motor.
Can someone recommend the correct motor or where to source a complete pump assembly for a 1996 Disco? The auto shop guy recommended Walbro 255 but said the're were 3 different types due to the connections locations: center or off-set to either left or right.
Thanks
cmpeng
dillhole
Feb 20, 2020 02:30 PM
willrok13
Mar 7, 2014 08:00 AM
VK71
Jun 4, 2013 07:51 AM
Street Wolf
Sep 6, 2011 04:15 AM
