Occasional Rough Idle - Low RPM
Old Sep 6, 2011 | 01:48 AM
Street Wolf's Avatar
Arrow Occasional Rough Idle - Low RPM
Just checking to see what the general consensus is as to what could be causing my problem. Only occasionally, My 00' DII will idle rough. Around the RPM range of 635-660 or so when in gear.
Old Sep 6, 2011 | 04:15 AM
Oh, the usual; plugs, wires, coils, sensors of choice (TPS, IACV), coolant leak (head gasket), vac hose leak somewhere (cracked or split). MAF needs cleaning, etc. Maybe look under the hood when it is pitch black dark and see if you can see any arc over from ignition related parts.
parke
Aug 25, 2014 09:55 PM
wrongway1
Mar 26, 2013 05:27 PM
mwyoung
Nov 2, 2011 12:28 PM
sidinseattle
Jul 16, 2010 10:21 PM
IDAHODISCO
Jul 10, 2009 09:34 PM
