Low Side A/C pressure
Old Jun 20, 2011 | 09:07 PM
adam123's Avatar
Default Low Side A/C pressure
anyone out there know what the low side a/c pressure should be?
my a/c quit on me because i was a dumb *** (pulled the wrong 30 amp fuse when i was disabling the abs valves) so i starting checking the refrigerant pressure before checking the fuses.
the low side was reading 110psi on the gauge. is that normal?
thanks
adam
Old Jun 20, 2011 | 09:12 PM
Dodger's Avatar
if the compressor was not running, yes 110psi is normal. When it is running the low side should fall between 25~40 psi in most cases.
Old Jun 20, 2011 | 09:24 PM
adam123's Avatar
cool, thanks
Classic89
Aug 10, 2007 08:58 PM
brooksn
Engine & Internal
May 18, 2006 03:23 PM
kpmaho
Mar 30, 2006 09:40 PM
kpmaho
Feb 23, 2005 04:39 PM
kpmaho
