Manual for cab removal and chassis repairs?
Old Dec 30, 2023 | 06:21 PM
GRAVZZY's Avatar
Default Manual for cab removal and chassis repairs?
Hello,
I've just bought a salvage Discovery 1 SD to repair another crash damaged one. I need to remove the cab to replace a bent radius arm on the chassis. My local authorities want me to supply the factory procedures for the cab removal and chassis repairs, including chassis welding specifications and sections replacement procedures... Have those manuals ever been available in the LR dealerships? I can't seem to find an official procedure neither for frame removal or chassis structural repair and weld...???
J-P
Old Dec 31, 2023 | 06:20 AM
WaltNYC's Avatar
there is a body repair manual in RAVE (the official workshop manuals). All that can be found in the google drive link in my sig. Download it and use it as you like.
Old Jan 1, 2024 | 05:51 AM
GRAVZZY's Avatar
Thanks for your answer WaltNYC, I've surfed through your manuals and had fun looking at the accessory fitting manual with the weird looking 90s aero body kits and spoiler, and I've read the Wabco abs manual for the first time, but I didn't find the procedure I'm looking for in any of the manuals. The body repair manual has a diagram with all the measurements to check if a frame is square, but other than that doesn't address frame repairs or replacement at all. There has to be an existing document about frame replacement at least, as some heavily rotten frames were replaced at the dealer under warranty. Maybe it was more like a technical service bulletin. I'll call my local dealer after the holidays and ask the service department if they find something and can give it to me; they will probably never use it again anyways...
Old Jan 1, 2024 | 11:06 AM
Harvlr's Avatar
I wouldn’t be surprised if there wasn’t a published procedure for R&R of the chassis.
Harear
Nov 29, 2021 03:10 AM
Anthony Gambale
May 5, 2021 06:34 PM
andrew12159
Mar 30, 2019 03:13 PM
DiscoNickBK
Oct 5, 2018 12:49 PM
collector87
Dec 21, 2014 04:24 PM
