Messed up my brakes!!
![Question](https://landroverforums.com/forum/images/icons/icon5.gif)
So I was in a rush yesterday and really needed new brake pads. I could not get the calipers to release the pads so I separated the calipers to release them. I did not read the manual ahead of time where it say DO NOT SEPARATE CALIPER. Now I do not have have pressure to the brakes. It is breaking as if it has no fluid but there is fluid. Any Ideas?
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
You've introduced mass amounts of air to the system. The only way you are going to get the pedal back is to bleed the brake system repeatedly until all air has been pushed out of the lines and calipers. This is probably not going to be easy, if you couldn't get the calipers to retract you probably have issues with them.
The calipers on these can be tricky. The bleeder and feed line are on the same side. You probably noticed the 2 seals between the caliper halves? They seal the crossover ports at the top and bottom. If one of these ports get gunk in it you can bleed the caliper all day and get nowhere, they both must be clear. Say the upper one is restricted, you can bleed the caliper but the fluid in the outer half doesn't push the air out because the upper port is blocked. You may also have gunk settled in the piston bores which will keep the pistons from going back in easily.
I had all these issues when I did my brakes. Rebuilding all 4 calipers corrected all the issues. Purchase the kits with the pistons, cheaper than buying everything separate. I got my parts from Rovahfarm, cost me about $160 to rebulid all 4 calipers and new pads all around.
British Pacific used to be a good source for caliper rebuild kits, too. Unfortunately they were just absorbed by Atlantic British and it doesn't look like AB has anywhere near the selection BP had.
It sounds as if your pistons are seized, most likely due to corrosion. You'll want to do a total caliper rebuild. This will include new pistons, wiper rings, sealing rings, and metal retaining rings. You should also try to find the channel seals that go between the caliper halves. You may have a really hard time finding these because LR doesn't want you splitting the calipers. Try Trevor at RovahFarm or PT Schram. Be aware the front and rear take different size pistons and channel seals, but share all the rings.
Make sure you clean the inside of the calipers very well. Blow compressed air through the channels.
Thanks everybody, I am going to try and bleed the system today. I actually did look at the seals in between and cleaned them. The pistons weren't seized as when I released the pressure from the fluid they pushed in to place. They have begun to set but when wanting to brake quickly it won't. I will update today what happens.
Exactly. Don't think of it as a bleed, think of it as a brake line flush and check it off the long term maintenance list!
knac1234
06-03-2009 07:51 PM
cellman01
05-08-2008 07:08 AM
