More than one inertia switch?
Old Sep 26, 2013 | 05:26 AM
  #21
pathas's Avatar
Originally Posted by EricTyrrell
My alarm definitely goes off if I'm driving on a rough road. I don't have locks anymore but the lights flash. Only way to get it to stop is shutdown and start it back up.
the alarm ECU changed in 1996. There is a definitive thread somewhere (either on this forum or at Discoweb) on how to bypass the alarm ECU on a 97 disco. Make sure your ECU is securely mounted. The vibration from the bumps are telling the ECU that you have been in an accident and to unlock the doors and turn on the hazards.
Old Sep 26, 2013 | 10:53 AM
  #22
wrongway1's Avatar
Originally Posted by Paul Grant
The alarm ECU is a green box that is mounted on a thin metal plate beneath the cruise contol ECU, ABS ECU and Window Lift ECU with a few 7mm bolts. It's not mounted anywhere near the chassis.
Not hijacking the thread, but you mention a cruise control ECU. Could this ECU be the reason my cruise control works for about 15 minutes and quits?? Once it quits, I need to restart the DI & it works again (well some times it does).
Old Sep 26, 2013 | 11:15 AM
  #23
EricTyrrell's Avatar
Yeah I'm just saying that's what happens sometimes and it's not a big deal. The only way I know of to actually remove the alarm is with a LR diagnostic system, which I do have but haven't done yet. Another guy here used a HawkEye to disable and remove his. You might be referring to the immobilization removal thread I created a while ago.
Old Nov 19, 2013 | 01:33 PM
  #24
pathas's Avatar
Default won't start
carp - today stupid truck won't start even when I make sure #1 wire is grounded to metal bracket. What do I do now?
Externet
Aug 26, 2013 06:45 PM
Discolife
Dec 2, 2011 03:44 PM
HOLSTOCK
May 8, 2010 05:18 PM
tophur
Feb 11, 2008 12:47 PM
castillo8071
Nov 13, 2007 10:54 AM
