My 98 land rover engine making a ticking noise
Old Apr 5, 2012 | 07:25 PM
Higgs Boson's Avatar
The lifters can all be changed in a matter of a few hours. The intake plenum(air horn) has to come off as well as the actual intake, and valve covers also. The valley pan is the actual intake gasket, it will need to be replaced anyway. Once that stuff is out of the way it's as simple as removing the rocker shaft and pushrods, then popping the lifters out. I can do this in about 3 hours, the average weekend warrior can probably get it done in an afternoon.
BUT, if the lifters are bad most likely the cam is on it's way south. There is NO adjustment for the rockers. Valve clearance is figured to center the lifter plunger at time of manufacture of the head. Valve stem height is part of the process when rebuilding these heads, as well as the Buick and Oldsmobile heads.
The mechanics you have consulted so far must not know this is a Buick pattern engine. Stupid easy to work on compared to what is out there today.
You would be better off selling the truck as it is. Unless you know how to work on it yourself it will cost you more than you will ever get back. You already have it priced at a loss to yourself, don't dig the hole any deeper.
Old Apr 5, 2012 | 10:39 PM
Nessa767's Avatar
Higgs boson, thanks for all that info seems like you know your rovers. I guess I'm better off selling as is. I'd rather not put more money into it
Old Apr 5, 2012 | 10:45 PM
Danny Lee 97 Disco's Avatar
List it on EBAY and see what you get!
Old Apr 6, 2012 | 08:00 AM
slanginsanjuan's Avatar
Next time I have a tough question needing a good simple explanation, I'm pretending I'm a girl.
Humdinger
Oct 18, 2016 05:05 PM
Nay_Sayer
Mar 19, 2014 09:35 AM
john65b
Oct 10, 2013 05:00 PM
Nikkiwi
Feb 20, 2013 06:32 PM
Carolina Tire
Oct 7, 2011 08:31 AM
