Need ac help...
Need ac help...
so i'm installing my new compressor, need to know what oil it takes. Under the hood says pag nd8, but no one sells that. searching google looks like nd8 is the equivalent of pag 46, but i just want to verify this before i throw it in, and advice would be appreciated, hopefully quick input as im pulling the old one off right now. thanks in advance.
I added PAG46 to mine a year ago. Seems fine, but can't say yes for sure. I pulled mine down to check for leaks. It was fine and I just replaced the oil I took out. Still blows just as cold with no ill effects on the internals of the compressor. I will add that you should work quickly as the PAG is very hygroscopic.
alti
03-13-2013 08:30 AM
striversrowatl
05-01-2010 11:20 AM
Speed racer
10-11-2008 10:56 PM
