Need ac help...
Old Dec 10, 2010 | 06:50 PM
dansgt's Avatar
Default Need ac help...
so i'm installing my new compressor, need to know what oil it takes. Under the hood says pag nd8, but no one sells that. searching google looks like nd8 is the equivalent of pag 46, but i just want to verify this before i throw it in, and advice would be appreciated, hopefully quick input as im pulling the old one off right now. thanks in advance.
Old Dec 10, 2010 | 08:01 PM
okdiscoguy's Avatar
I added PAG46 to mine a year ago. Seems fine, but can't say yes for sure. I pulled mine down to check for leaks. It was fine and I just replaced the oil I took out. Still blows just as cold with no ill effects on the internals of the compressor. I will add that you should work quickly as the PAG is very hygroscopic.
Old Dec 10, 2010 | 09:34 PM
dansgt's Avatar
great just the answer i was looking for. new ones on and it'll be charged up tomorrow. also took out some ghetto bypass wiring from the po so hopefully the compressor was the reason he bypassed the factory wiring for it haha.
ScreamingLife
Apr 25, 2013 08:32 PM
MuddMouth
Oct 18, 2010 03:01 PM
striversrowatl
May 1, 2010 11:20 AM
Speed racer
Oct 11, 2008 10:56 PM
