need to fine a radio harness
Old Jul 2, 2010 | 05:05 PM
turbogregtn's Avatar
Default need to fine a radio harness
where can i get a radio harness for a after market radio? i think i have a factory amp as well and want to keep it. OR dose any one have a wiring diagram for the land rover radio harness? mines a 97
Old Jul 2, 2010 | 05:35 PM
greg409's Avatar
One of several on the net
http://www.autotoys.com/x/product.php?productid=1474
Both of mine got new wire pulled, I felt leaving the old and pulling new was actually easier and the factory amps use low-impedence signal from factory head.
luck,greg
Old Jul 3, 2010 | 09:00 AM
indy11bravo's Avatar
97 disco radio thread
The above is the thread for when i replaced the radio in mine. It was pretty easy, but as stated in the thread, make sure you run a new ground from the back of the new head unit. The factory ground that goes into the harness is not sufficient. The link to the harness i used is in the thread linked above.
Old Jul 3, 2010 | 11:41 PM
sure will i just ordered one thanks for the info
theswede
Oct 29, 2015 01:05 AM
davidstereo
Sep 14, 2010 09:26 AM
05LR3AZ
Audio/Visual Electronics
Jun 24, 2009 03:06 PM
tomfraser
Mar 1, 2009 09:29 PM
