need fuel sender gasket
CIP rubber lubricant
Checked with the MFG and CIP is great but for our purposes they make a similar product that is waterproof and has a higher melting point. Its called "Petro Gel". Comes in 4 oz tubes. I have some coming now, if it turns out as good as it sounds it will be a godsend for any rubber components (radiator hoses, gaskets etc.) I will let you guys know what shakes when I try it. Dach.
I just smeared thin bearing grease on it and the sender figured it can dissolve in the gasoline and won't hurt the seal which was shrunk and I had to work it around the sender with a pic, pita
Hard part is you won't find the seal in a junk yard cause they pull the tanks, no tank no sender
mudslinger
07-13-2010 03:17 PM
wizwith
04-30-2010 12:11 PM
