Need help with my 96 Disco
Old 02-29-2012, 03:15 PM
El MEXSA kon la Discovery's Avatar
Default Need help with my 96 Disco
I have a 96 Disco it runs good and everything works okay. But when i driver around an 1 hour and stop turn it off and they turn it on agian it will driver good until it losen power on the gas and if i step on it it will backfire and wont move?
I need help to see what is wrong with it i already checnge the fuel filter.
Old 02-29-2012, 04:18 PM
Probably a good time to check the fuel pump pressure, there is a valve like a tire valve on the passenger side fuel rail, expect 32-34 PSI there with truck running.
If problem only happens when truck is warmed up, may want to check the crank position sensor, back of engine, driver side; you can pour cold water on it to cool it off. It will eventually get so bad truck won't crank.
Check engine light on? Time to read codes.
Old 03-01-2012, 10:27 AM
Default okay
okay i will go ahead and try that. i will let you know what happens and i will see what codes it has. I so ahead and put cold water on the crank to see it helps.
THnaks
Old 03-01-2012, 10:44 AM
Here's a pix of the sensor, this one is on a Discovery 2, but same area. The wire leads down to that box on the engine, which covers the sensor.
File Type: pdf
ScreamingLife
04-25-2013 08:32 PM
striversrowatl
05-01-2010 11:20 AM
Speed racer
10-11-2008 10:56 PM
Quick Reply: Need help with my 96 Disco
