Need help with my 96 Disco
I have a 96 Disco it runs good and everything works okay. But when i driver around an 1 hour and stop turn it off and they turn it on agian it will driver good until it losen power on the gas and if i step on it it will backfire and wont move?
I need help to see what is wrong with it i already checnge the fuel filter.
Probably a good time to check the fuel pump pressure, there is a valve like a tire valve on the passenger side fuel rail, expect 32-34 PSI there with truck running.
If problem only happens when truck is warmed up, may want to check the crank position sensor, back of engine, driver side; you can pour cold water on it to cool it off. It will eventually get so bad truck won't crank.
Check engine light on? Time to read codes.
ScreamingLife
Apr 25, 2013 08:32 PM
alti
Mar 13, 2013 08:30 AM
whurst79
Jan 28, 2013 09:24 PM
striversrowatl
May 1, 2010 11:20 AM
Speed racer
Oct 11, 2008 10:56 PM
