Need help with O2 sensors
Do you have ability to work on it yourself?
If not I would see if someone on here can recommend a reputable shop specializing in rovers
if you read enough here you will see why not just any shop should work on it "they waste your $ hunting obvious things to a rover mech"
Do you run hot or lose coolant?
You'll have to do some reading because I don't know if the NAS has the ROW maps too but by changing the tune select resistor you'll be selecting different maps/equipment. That's what the tune select resistor does, sets maps for a particular market. They run without either just fine by hard defined values rather than adaptive.
