Need help with O2 sensors
Old Feb 7, 2014 | 06:45 PM
TOM R's Avatar
Do you have ability to work on it yourself?
If not I would see if someone on here can recommend a reputable shop specializing in rovers
if you read enough here you will see why not just any shop should work on it "they waste your $ hunting obvious things to a rover mech"
Do you run hot or lose coolant?
Old Feb 7, 2014 | 06:49 PM
Nay_Sayer's Avatar
No.
It ran hot in the past but replacing the thermostat cured that problem and it hasn't run hot since..
Old Feb 7, 2014 | 07:43 PM
TOM R's Avatar
Be sure the shop knows you overheated in the past, these are notorious for head gaskets all the more reason for a rover shop, antifreeze kills 02 sensors just to keep in mind
Old Feb 8, 2014 | 08:32 PM
calebbo's Avatar
If installing a new exhaust system can I cut out my cats and O2 sensors if I have a 95 obd1 discovery? We only have two 02 sensors and as far as I can tell through research there would be no ill effects. Oh and no emission testing either
Old Feb 9, 2014 | 07:43 AM
TOM R's Avatar
Can remove cats, if inspection allows, upstream 02 sensors must be kept it is what's telling ecm fueling
Old Feb 9, 2014 | 08:37 AM
abran's Avatar
I have a Y pipe with the cats removed and straight pipes welded in. I can't use it as I am in CA. I'll give it to you if you pay for shipping...
Old Feb 9, 2014 | 04:05 PM
calebbo's Avatar
So is I remove them it will decrease my fuel efficiency yeah?
Old Feb 9, 2014 | 05:33 PM
TOM R's Avatar
Remove the o2 and the engine will never run correct again, ecm limp mode cell light on and probly 1 MPG if you are lucky till you flood the engine and kill it, IMO
Old Feb 9, 2014 | 08:26 PM
ihscouts's Avatar
You'll have to do some reading because I don't know if the NAS has the ROW maps too but by changing the tune select resistor you'll be selecting different maps/equipment. That's what the tune select resistor does, sets maps for a particular market. They run without either just fine by hard defined values rather than adaptive.
Old Feb 9, 2014 | 08:41 PM
TOM R's Avatar
Obd1 on rover must be waay different then us vehicles huh?
