New disco owner
Old May 10, 2012 | 12:47 PM
discoguy96's Avatar
Default New disco owner
I just traded one of my motorcycles to my father-in-law for his 1996 Discovery SD. I'll get into the good and bad of the vehicle in a later post but for now I had a question about towing.
I have a 20' Komfort lite travel trailer with electric brakes. The disco has a trailer connector in the back but do I need to install a seperate trailer brake controller or is that function already built in to the disco's wiring?
Thanks all and I will try to put up some pics this evening.
Old May 10, 2012 | 01:06 PM
Controller is not built in. Download the RAVE below, a factory manual set, incluidng owners manual, which has towing limits.
Old May 10, 2012 | 03:42 PM
Danny Lee 97 Disco's Avatar
There was also something about people having some issues trying to use the stock Discovery trailer plug with the US version of trailer wiring. I do not recall the specifics involved, so do a search before you hook up and fry something.
Old May 10, 2012 | 07:29 PM
oilspotLR's Avatar
You need a connector. Atlantic British sells
them.
Land Rover Trailer Wiring Kit (Same Fit As Genuine Part # WIRING KIT)
Old May 10, 2012 | 11:17 PM
discoguy96's Avatar
them.
That looks like it converts the disco's wiring to a flat four but my trailer connection isn't flat four(it's round) and I would still need a brake controller, so i'm not sure if that will do me any good.
Old May 11, 2012 | 04:42 AM
Wiring attached from RAVE, connector is inside right rear, remove panel inside truck like you were changing a tail light bulb. Download the whole RAVE and you will have wire color code, photos of locations, connector pin-outs, etc.
Here's towing capacity from owner's guide, also in the RAVE:
TOWING WEIGHTS
On-road.............................................. .................................................. Off-road
Unbraked trailers .................................................. . 1650 lb (750 kg)....1650 lb (750 kg)
Trailers with brakes - high range ........................... 5500 lb (2495 kg).. 2200 lb (995 kg)
Trailers with brakes - low range ............................. 7700 lb (3490 kg) -
Roof rack load .................................................. ..... 110 lb (50 kg) **
Maximum permissible tongue weight .................... 330 lb (150 kg)
NOTE:
File Type: pdf
Old May 11, 2012 | 08:59 AM
discoguy96's Avatar
I have the owner's manual and I am downloading all of the other manuals. Thank you for the wiring pdf.
Run33
May 11, 2015 09:43 PM
kayak74
Jan 23, 2013 07:13 AM
jswift
Jun 21, 2011 12:12 PM
MuddMouth
Sep 30, 2010 10:30 PM
desh72
May 5, 2007 12:03 AM
