New Owner with PROBLEM! :(
Old Oct 23, 2013 | 08:52 PM
TOM R's Avatar
My 98 d1 is 4.0 do you have a distributed at front of engine?
Sensor should be unplug undo screw/bolt holding it to the engine, pull from engine then reverse order
I can't say for sure it the problem with a kit added in like that
Old Oct 23, 2013 | 10:30 PM
richardfeynman's Avatar
4wd High
Yes distributor is at the front. Is there a photo of what it looks like?
Old Oct 23, 2013 | 11:38 PM
4wd High
UPDATE: Ok so I switched it over to petrol after washing the very greasy engine down. The revs have become more consistent! And it is idling much better, not perfect but much better.
Old Oct 24, 2013 | 06:40 AM
TOM R's Avatar
Every 1998 d1 I have seen is 4.0 and does not have a distributer, supposed to be coils mounted behind the intake, I could be wrong
If you have a distributed there is a part in it that goes bad look in the tech section, also check all your grounds, I get the feeling you got a franken rover
Post pics
Run33
May 11, 2015 09:43 PM
guy2545
Apr 11, 2010 06:55 AM
substantialiscious
Jan 8, 2010 09:48 AM
pressure_welder
Oct 6, 2008 02:52 PM
ctcnewton
Feb 18, 2006 12:32 AM
