New vs Old Cam Gear Pics
Old Nov 16, 2011 | 06:33 PM
EricTyrrell's Avatar
Default New vs Old Cam Gear Pics
New gear left, old right. New is from British Pacific, Allmakes brand, unknown manufacturer.
It fits on much tighter, there were bits of casting material or something left in the corners, and the key is a bit too wide so that it actually chiseled out the keyway on my cam putting it on. It has a dark grey, slightly pitted, slightly uneven, but very smooth surface. They good part is it seems very hard. They key showed no signs of wear even after being hammered onto the cam, and it completely resisted my attempted grinding with a stainless steel wheel.
Attached Thumbnails New vs Old Cam Gear Pics-img_1817.jpg   New vs Old Cam Gear Pics-img_1818.jpg   New vs Old Cam Gear Pics-img_1819.jpg
Old Nov 16, 2011 | 06:42 PM
Pics of fitment consequences to cam.
Attached Thumbnails New vs Old Cam Gear Pics-img_1821.jpg   New vs Old Cam Gear Pics-img_1822.jpg
Old Nov 16, 2011 | 06:47 PM
Teeth shot.
Old Nov 16, 2011 | 07:14 PM
Gear teeth - cast on left, machined on right? Seems like machined might be a step up, more precise?
Old Nov 16, 2011 | 07:28 PM
Same order, new left, old right.
Old Nov 17, 2011 | 10:06 AM
wheelgarage's Avatar
Hummm....that cam gear in cast isn't the business, hence the issue with the cam. The scratches on the cam should be an issue. I just hope that gear doesn't fracture down the road.
Old Nov 17, 2011 | 10:23 AM
Bet you it is from China, I would have sent it back along with a letter and picture to British Pacific.
I would suggest anyone needing a new gear set make sure it is American made.
Old Nov 17, 2011 | 11:29 AM
psykokid's Avatar
Since the motor is essentially a buick 215 would a cam gear set by one of the reputable aftermarket mfg's for a buick work? I recall seeing someone mention a source/part number for something that would work but i cant seem to find it via search..
Old Nov 17, 2011 | 11:50 AM
ValveCoverGasket's Avatar
interesting idea
would be fun to also get a hotter buick cam in there as well
Old Nov 17, 2011 | 12:26 PM
psykokid's Avatar
also, kent and piper in the uk make rover v8 cams that are a little hotter than the bog stock rover item..
- also found the info on the timing gear set on dweb:
Originally Posted by dweb
Not sure if this helps, but a Cloyes 9-3132 supposedly fits our motors:
http://www.jegs.com/i/Cloyes/220/9-3132/10002/-1
