no high beams
Old Jun 6, 2015 | 08:40 PM
notny41's Avatar
Default no high beams
hey guys - I have low beams but as soon as I pull the stalk to put the brights on I get nothing from the headlights (other than the little amber lights in there).
I checked the bulbs - they look good (they are basically brand new), I checked fuses 4 and 5 under the dash and they are both good.
I suppose it could be the stalk, but how likely is that?
short of pulling out the multimeter is there anything else somewhat obvious that I am missing here?
Old Jun 7, 2015 | 07:59 AM
ihscouts's Avatar
"How likely is that?" Reply; Does the Earth orbit the Sun? What you do next is how effectively you can answer that question...... or feed oneself without a caregiver.
I'd check the wire connection on the light switch for heat/corrosion and proceed. If neither is present then it's the contact for high beams which put out just a few more watts than low........
Old Jun 7, 2015 | 08:23 AM
notny41's Avatar
I'm a little confused on what you are telling me to do. What's the procedure for checking the contacts on that light switch?
Old Jun 7, 2015 | 10:42 AM
ihscouts's Avatar
I see, not a self feeder.....
Eyeballs is the procedure. Take the column shroud off, remove the stalk switch and look at the connections. Tell me there isn't one (labeled #3 on the switch) that isn't brown and distorted.
What do you think you can accomplish with a V/O meter? There isn't power to the switch? There is. There isn't power from the switch to the high beams? There isn't. See, did all the work for ya.
LeethalG32
Sep 13, 2023 06:12 PM
'BamaBoy
Jul 14, 2013 08:27 AM
gunsanroses91
Oct 6, 2012 08:59 PM
Kari J
Aug 19, 2009 07:35 AM
