no one said it had to be pretty.. did they?
Old Dec 15, 2018 | 10:29 PM
rickroverover's Avatar
Default no one said it had to be pretty.. did they?
temporary - till it gets warm enough to use better 18 gauge and proper auto panel bonding (must be over 65 to set) I will also cut away more of the rust next time. This was some $5.00 loctite stuff from Lowes that sets in temps as low a 40 degrees - just what I needed. It is hard and locked on to the surface even after using fluid film to neutralize the rust.
The small bolts holding the mudflap bracket were spinning on top - from rust. Will need to uncover the whole floor this summer.
Will shoot with self etching primer on the first day it gets above 55 Deg here
If I place some 22 gauge inside and sandwich some good stuff inbetween I may let this ride till the whole fender liner is ready to be replaced..
surprised how hard this stuff set up - but it did take a while
Old Dec 16, 2018 | 08:42 AM
Toran's Avatar
Looks like I am in line for similar treatment as one of my mudflap fell off.
Thanks for sharing.
Old Dec 16, 2018 | 07:01 PM
Brentski's Avatar
4th Gear
They did not, but, it does look good.
Old Dec 16, 2018 | 09:48 PM
highly recommended... There is a youtube video on this item.
Used to get into corners and break away all the bad stuff
Old Dec 20, 2018 | 10:25 AM
user132545's Avatar
If its not looking weathered any more that is pretty to me haha
bosshogt
Jun 12, 2021 11:50 PM
TRIARII
Build Threads
236
May 12, 2021 04:35 PM
originalpy
Jul 2, 2019 04:20 PM
pinkytoe69
Mar 31, 2016 12:34 PM
LR03NJ
Mar 20, 2016 06:37 PM
