No power to rear windows
Old Mar 2, 2017 | 09:52 PM
jimvw57's Avatar
I had the same problem years ago and added the splice , which takes care of the rear windows. I then resoldered the board to fix the pass window. Now it started doing it again so I think this time I will add some wire to strengthen the solder joint cracking issue
Old Mar 7, 2017 | 07:12 PM
ryanpaulaf1's Avatar
4th Gear
jimvw57, just to reiterate I have an 2007 Land Rover LR3. I'm looking in the place others have mentioned for the ECU, however i'm not seeing it. Is there a different location for the ECU in my particular vehicle? If not, are there any specific location you can give me or pictures referencing it's location? Thanks.
Old Mar 12, 2017 | 05:57 AM
jimvw57's Avatar
I have a LR1 1997 and the ECU is behind the glove box (and a little below ) Not sure if the LR3 is the same or not. I would check the RAVE
You are in the Discovery 1 section of the forum
Old Mar 13, 2017 | 08:14 AM
CDN_Expat's Avatar
Question Same problem on 93 Disco but no glovebox..where's the circuit board?
My rear windows are also not working from either set of switches..I switched the working front switches over to the back and still no joy. I'd like to try to resolder the circuit board but I can't find it on my 93.
The rave manual seems to be for the 1994 and up as far as I can tell or am I wrong? There's no glovebox on my model. Anyone know if/where the window circuit board is on a 93 Disco or if there's a different fix besides bypassing? Thanks!
Old Mar 13, 2017 | 11:25 AM
4th Gear
Jimvw57, what do you mean by "check the RAVE"? Thanks.
Old Mar 13, 2017 | 09:42 PM
jimvw57's Avatar
There are online manuals for all the land rovers called RAVE manuals. you can download the one for your truck and it will tell you everything. there are Electrical, Body and mechanical. I don't have the link for them but if you do a search you will find them.
After taking A look I found this link. I guess they don't have a complete book for the LR3 just sections
https://landroverforums.com/forum/lr...ownload-78311/
Old Mar 14, 2017 | 08:28 AM
WaltNYC's Avatar
click the link in my signature and you'll find it all.
acibarich
Jun 5, 2013 08:57 AM
Quarterbroad
Mar 25, 2011 11:03 AM
booper169
Nov 9, 2010 09:10 AM
LIVE4DISCO
Apr 20, 2010 06:54 PM
Fox900
Sep 29, 2007 12:51 AM
