No Spark 97 Disco 1
Old Apr 24, 2012 | 10:26 AM
scottshack's Avatar
4wd High
Default No Spark 97 Disco 1
Few weeks back I was out in the desert wheeling and we stopped to take a break. Went to start up and it would not fire. No Spark. I just got a chance to work on it the other day. No codes were logged, replaced the CPS still no spark. Swapped out my extra coil pack, still no spark. Any ideas on what could be causing this? It was running fine up until the point I shut her down. Also she was having trouble starting once warm, figured my fuel temp sensor might be going out, but that shouldn't give me a no spark problem to my knowledge. Thanks for any help you guys can provide.
Scott
Old Apr 24, 2012 | 11:07 AM
If spacers for CKP (crank shaft sensor) did not go back on right, it would not work. Very precise fit. Or ECU and/or fuses. See attached.
File Type: pdf
File Type: pdf
Old Apr 24, 2012 | 04:41 PM
Jake1996D1's Avatar
Also as with all 15+ year old vehicles check the wiring to the sensor as well.. CKPS is pretty much the only think I know of that will deactivate spark. Besides shot or disconnected coil..
mikedemet
Jan 29, 2021 02:02 PM
pbgelber
Aug 6, 2008 09:47 AM
NWDisco
Dec 13, 2006 03:11 AM
aremee
Sep 30, 2006 05:47 PM
aremee
Sep 27, 2006 11:01 PM
