Disconnected battery 97 Disco, no spark now!
Old Sep 30, 2006 | 10:46 AM
aremee's Avatar
8th Gear
Default Disconnected battery 97 Disco, no spark now!
I disconnected the battery on my 97 Disco. New battery went in, car cranks but doesn't start. Ignition key has delay of about 2 secs. before it engages starter, alarm, door locks, are working fine with remote and key. Any ideas? I need help bad!
Old Sep 30, 2006 | 11:01 AM
Default RE: Disconnected battery 97 Disco, no spark now!
I would say your alarm is not working fine, is it factory or aftermarket??
Mike
Old Sep 30, 2006 | 01:12 PM
Brad S1's Avatar
ORIGINAL: Disco Mike
Mike
Yeah when I pulled my batt last week I had the same issue and traced it back to the same fuse that keeps blowing, I think it's either 13 or 18, some alarm fuse... When it goes the truck either just cranks or nothing... pulled that batt again, replaced the fuse, plugged it back in, unlocked the truck, starts fine...
Old Sep 30, 2006 | 05:45 PM
aremee's Avatar
8th Gear
I know 13 is alarm fuse that seems to be fine. I pulled and replaced all fuses when I was searching for draw. Found ALT was causing draw. Hooked battery back up, no spark. Until then truck was perfect. Do you use key fob to unlock and lock?
Old Sep 30, 2006 | 05:47 PM
aremee's Avatar
8th Gear
Factory alarm nothing aftermarket.
cheqbay1997
Mar 1, 2018 08:23 AM
KernowDiscovery
Feb 17, 2016 03:24 PM
slabrat
Apr 11, 2013 01:16 PM
fezzr
Mar 18, 2012 12:20 AM
VCO
Oct 17, 2011 09:07 PM
